I want to program a FPGA cyclone IV EP4CE15F17I7 but I do not know how to do it. I would like to know how I could do it also how to get a source file of one FPGA for programing another with the same file.
Are you using a Development kit?
- Check which configuration scheme is used on your board.
- Refer below user-guide for programming steps session 4.1.
To get source files from flash, You have you use the flash loader to establish a bridge between flash and cable. Refer below link
https://www.intel.com/content/www/us/en/programmable/documentation/mwh1410805299012.html
After loading flash loader (sof) in FPGA auto-detect and use the Examine feature in the Quartus® II Programmer to read back the .pof. You can then save this file and use it to program other EPCS devices
Anand
I am not using any Development kit, I have two FPGA EP4CE15F17I7 in other board and I want to know if I can program it because I read that this FPGA do not have a ROM memory internally and I do not know how to program if only have a RAM memory. Could you tell me if the information I read is correct? or where can I get more information about it?
I am checking your information but I am a new to program FPGAs.
jalon5
Hi Juan,
Yes, FPGA do not have a ROM memory internally but we can use external rom like EPCS device as flash.
Now you have to read the configuration image (.pof) from external flash.
Anand
