Programmable Devices
21608 Discussions
How to reduce Interconnect Delay?!
I have designed a mux in Cyclone IV-E device.
I need to meet the Pin to Pin delay constraint of 10 ns.
Tools used are Quartus II 14.0 and Timequest.
I am geting data path with delay of 13.309ns...IC delay of this path is found to be ~7.5ns:(:confused:
Part of report is added below.
Slack
From Node
To Node
Launch Clock
Latch Clock
Relationship
Clock Skew
Data Delay
-3.309
unc_jtag_tdi
tdi_unc2
n/a
n/a
10
13.309
Is it possible to reduce this delay?
The logic implemented is a combo mux!
I have even tried a direct pin to pin mapping wihout any logic...and data delay is 7.496 for that(IC Delay is 3.640ns)!!
Neeraj G N
Why do launch and latch clocks say n/a?
Can you post code and relevant SDC?
Hi sstrell,
Thanks for your time.
Launch and latch clock is not present because its an input to output data path.
code is added below, all signals are I/O s.
always @(jtag_mux_sel or unc_jtag_tdi or unc_jtag_trst_l or unc_jtag_tms or unc_jtag_tck or tdo_unc0 or tdo_unc1 or tdo_unc2 or tdo_unc3)
begin
case(jtag_mux_sel)
2'b00:begin
unc_jtag_tdo = tdo_unc0;
tdi_unc0 = unc_jtag_tdi;
trst_l_unc0 = unc_jtag_trst_l;
tms_unc0 = unc_jtag_tms;
tck_unc0 = unc_jtag_tck;
tdi_unc1 = 1'b0;
trst_l_unc1 = 1'b0;
tms_unc1 = 1'b0;
tck_unc1 = 1'b0;
tdi_unc2 = 1'b0;
trst_l_unc2 = 1'b0;
tms_unc2 = 1'b0;
tck_unc2 = 1'b0;
tdi_unc3 = 1'b0;
trst_l_unc3 = 1'b0;
tms_unc3 = 1'b0;
tck_unc3 = 1'b0;
end
2'b01:begin
tdi_unc0 = 1'b0;
trst_l_unc0 = 1'b0;
tms_unc0 = 1'b0;
tck_unc0 = 1'b0;
unc_jtag_tdo = tdo_unc1;
tdi_unc1 = unc_jtag_tdi;
trst_l_unc1 = unc_jtag_trst_l;
tms_unc1 = unc_jtag_tms;
tck_unc1 = unc_jtag_tck;
tdi_unc2 = 1'b0;
trst_l_unc2 = 1'b0;
tms_unc2 = 1'b0;
tck_unc2 = 1'b0;
tdi_unc3 = 1'b0;
trst_l_unc3 = 1'b0;
tms_unc3 = 1'b0;
tck_unc3 = 1'b0;
end
2'b10:begin
tdi_unc0 = 1'b0;
trst_l_unc0 = 1'b0;
tms_unc0 = 1'b0;
tck_unc0 = 1'b0;
tdi_unc1 = 1'b0;
trst_l_unc1 = 1'b0;
tms_unc1 = 1'b0;
tck_unc1 = 1'b0;
unc_jtag_tdo = tdo_unc2;
tdi_unc2 = unc_jtag_tdi;
trst_l_unc2 = unc_jtag_trst_l;
tms_unc2 = unc_jtag_tms;
tck_unc2 = unc_jtag_tck;
tdi_unc3 = 1'b0;
trst_l_unc3 = 1'b0;
tms_unc3 = 1'b0;
tck_unc3 = 1'b0;
end
2'b11:begin
tdi_unc0 = 1'b0;
trst_l_unc0 = 1'b0;
tms_unc0 = 1'b0;
tck_unc0 = 1'b0;
tdi_unc1 = 1'b0;
trst_l_unc1 = 1'b0;
tms_unc1 = 1'b0;
tck_unc1 = 1'b0;
tdi_unc2 = 1'b0;
trst_l_unc2 = 1'b0;
tms_unc2 = 1'b0;
tck_unc2 = 1'b0;
unc_jtag_tdo = tdo_unc3;
tdi_unc3 = unc_jtag_tdi;
trst_l_unc3 = unc_jtag_trst_l;
tms_unc3 = unc_jtag_tms;
tck_unc3 = unc_jtag_tck;
end
default:begin
tdi_unc1 = 1'b0;
trst_l_unc1 = 1'b0;
tms_unc1 = 1'b0;
tck_unc1 = 1'b0;
tdi_unc2 = 1'b0;
trst_l_unc2 = 1'b0;
tms_unc2 = 1'b0;
tck_unc2 = 1'b0;
tdi_unc3 = 1'b0;
trst_l_unc3 = 1'b0;
tms_unc3 = 1'b0;
tck_unc3 = 1'b0;
end
endcase
end
# ###SDC is added below####
set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc0}] 10.000
set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc1}] 10.000
set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc2}] 10.000
set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc3}] 10.000
set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc0}] 10.000
set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc1}] 10.000
set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc2}] 10.000
set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc3}] 10.000
set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc0}] 10.000
set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc1}] 10.000
set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc2}] 10.000
set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc3}] 10.000
set_max_delay -from [get_ports {tdo_unc0}] -to [get_ports {unc_jtag_tdo}] 10.000
set_max_delay -from [get_ports {tdo_unc1}] -to [get_ports {unc_jtag_tdo}] 10.000
set_max_delay -from [get_ports {tdo_unc2}] -to [get_ports {unc_jtag_tdo}] 10.000
set_max_delay -from [get_ports {tdo_unc3}] -to [get_ports {unc_jtag_tdo}] 10.000
set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc0}] 5.000
set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc1}] 5.000
set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc2}] 5.000
set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc3}] 5.000
set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc0}] 5.000
set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc1}] 5.000
set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc2}] 5.000
set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc3}] 5.000
set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc0}] 5.000
set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc1}] 5.000
set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc2}] 5.000
set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc3}] 5.000
set_min_delay -from [get_ports {tdo_unc0}] -to [get_ports {unc_jtag_tdo}] 5.000
set_min_delay -from [get_ports {tdo_unc1}] -to [get_ports {unc_jtag_tdo}] 5.000
set_min_delay -from [get_ports {tdo_unc2}] -to [get_ports {unc_jtag_tdo}] 5.000
set_min_delay -from [get_ports {tdo_unc3}] -to [get_ports {unc_jtag_tdo}] 5.000
Neeraj
I'm pretty sure you'd need to constrain the two pins to a virtual clock, otherwise I don't think Quartus is actually going to treat that as a timed path.
