Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
How to register DSP builder 13.1 blockset in MATLAB2012b?
I have installed both MATLAB2012b and DSP builder13.1 (both compatible), but the standard blockset does not show up in the simulink library. Any help will be much appreciated.
Are you launching MATLAB directly?
You should use script to launch.
  1. Start MATLAB.
  2. Run the set-up script by typing the following at the MATLAB prompt:
Check the link
https://www.altera.com/support/support-resources/intellectual-property/dsp/dsp-builder/ips-dsp-build...
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
