21611 Discussions
How to set timing constraint to uart
XQSHEN
uart is  used as interface of external device. And this device has it's owner clock. When doing timing constraint, should I set uart rxd and txd as false path? or setting timing constraint using virtual clock? or  just set max delay?
KhaiChein_Y_Intel
You may constrain the I/O signal max and min delay with reference to the virtual clock and any timing exceptions if applicable. You may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_timequest_cookbook.pdf (Page 9 I/O Constraints)
KhaiY
XQSHEN
as there is no directly between FPGA clock and external device clock, how do you define the max or min limit?
KhaiChein_Y_Intel
Do you mean there is no direct relationship between the FPGA clock and external clock? Could you elaborate?
KhaiY
XQSHEN
Yes. They are two individual device using uart to communicate.
FPGA ------uart---------external device(wifi module).
XQSHEN
1. FPGA has its own clock
2. Wifi module has its own clock
KhaiChein_Y_Intel
If they are asynchronous, you may set false path or set multicycle if they are synchronous.
KhaiY
KhaiChein_Y_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
KhaiY
