21592 Discussions
How to solve modelsim simulation fir compiler Library auk_dspip_lib not found?
https://alteraforum.com/forum/attachment.php?attachmentid=13858&stc=1 Hello, I am an FPGA beginner, and when I use modelsim simulation fir compiler appeared "library auk_dspip_lib not found, Unknown identifier "auk_dspip_lib, VHDL Compiler exiting." I have added the .vo file to the project ,why this is the case? Can you elaborate on how to solve this problem in detail? Can be accompanied by a detailed solution to the process is the best! system is win10 x64 rs2, quartus is 13.1, modelsim is altera 10.1d.
From Error message It looks like VHDL file is looking for a missing library.
make use of auto-generated script for setting up any IP simulation.
It is generated from Qsys under directory
<myip>/simulation/mentor/msim_setup.tcl
Follow steps as below.
1. Open Modelsim Navigate to location of scripts.
2. do msim_setup.tcl
3. ld_debug
arslanusman2003
(This message was posted on behalf of Intel Corporation)
