21324 Discussions
How to solve nSTATUS can't go high
I have made a FPGA board using Cyclone V SOC 5CSXFC6D6F; The HPS is running, the Quartus Programmer can detect the HPS(SOC part), but the FPGA part can't be detect via JTAG; and I've found the nSTATUS can't go high after power up, but generate a pulse about 4.3kHz.
Are all the power supplies to the FPGA up and correct? Are all the power pins receiving the right voltage? Are you pulling nSTATUS up with a suitable pullup resistor to an appropriate rail?
--- Quote Start ---
--- Quote End ---
Via JTAG?
For the JTAG chain to be partially working but not find the FPGA I'd suspect one of the above.
Alex
