hello, i trying to test an spi module that i add in a system that im using, i used this code but i dont know why there is an error:
/* * principal.c * * Created on: 11/04/2012 * Author: RONALD */ # include <stdio.h># include "system.h" # define ALT_MODULE_CLASS_SPI_1 altera_avalon_spi# define SPI_1_NAME "/dev/SPI_1" int main() { FILE *fp; printf("Hello from Nios II!\n"); // fp = fopen("/dev/SPI_1","r+"); //opens module spi if(fp==0)//if doesnt exist the module do this printf("\nError Opening %s\n\n",SPI_1_BASE); else//do this if the module exists { printf( ""spi comunication success \n"); } return 0; } when i run this code for to test the spi module the program shows me ""Error Opening", could you help me with these pleaseLink Copied
You can't use the file API to use a SPI master, it uses its own API. Have a look at this document (http://www.altera.com/literature/ug/ug_embedded_ip.pdf), pages 8-8 and over, for more details about the SPI controller API.
Hello Daixiwen, thanks for your help, but my SPI module is configurated as slave, how can i test my SPI module if it is a slave??, Could you send me some example code?? thanks in advance, sorry if i am not clear, im an ecuadorian student, i speak spanish but i know some english :-), im doing a SPI analyzer, it is my graduation proyect, and until know i have my machine in qsys, now i want to test my modules created, i´m going to need a uart module, and with a code similar to the code that i told you in the post, i tested it and it worked, but with my spi slave dont :-(, im new in altera forums, help me wwith this pease. thanks again
AFAIK altera_avalon_spi can only be a master and can't be configured as a slave.
Did you read the document I suggested you? It describes the alt_avalon_spi_command() function that you can call to send SPI commands.- Subscribe to RSS Feed
