Programmable Devices
20703 Discussions
How to use only one channel on ADC port Max10
EEren
I have an ADC core
component adc_qsys is
	port (
		adc_1_command_valid          : in  std_logic                     := '0';             --  adc_1_command.valid
		adc_1_command_channel        : in  std_logic_vector(4 downto 0)  := (others => '0'); --               .channel
		adc_1_command_startofpacket  : in  std_logic                     := '0';             --               .startofpacket
		adc_1_command_endofpacket    : in  std_logic                     := '0';             --               .endofpacket
		adc_1_command_ready          : out std_logic;                                        --               .ready
		adc_1_response_valid         : out std_logic;                                        -- adc_1_response.valid
		adc_1_response_channel       : out std_logic_vector(4 downto 0);                     --               .channel
		adc_1_response_data          : out std_logic_vector(11 downto 0);                    --               .data
		adc_1_response_startofpacket : out std_logic;                                        --               .startofpacket
		adc_1_response_endofpacket   : out std_logic;                                        --               .endofpacket
		clk_clk                      : in  std_logic                     := '0';             --            clk.clk
		reset_reset_n                : in  std_logic                     := '0'              --          reset.reset_n
end component adc_qsys;
U_ADC_SYS : adc_qsys
port map
	clk_clk        => s_pll_clk_10M,
	reset_reset_n  => '1',
	adc_1_command_valid          => adc1_com_valid,
	adc_1_command_channel        => adc1_com_channel,
	adc_1_command_startofpacket  => adc1_com_startofpacket,
	adc_1_command_endofpacket    => adc1_com_endofpacket,
	adc_1_command_ready          => adc1_com_ready,
	adc_1_response_valid         => adc1_resp_valid,
	adc_1_response_channel       => adc1_resp_channel,
	adc_1_response_data          => adc1_resp_data,
	adc_1_response_startofpacket => adc1_resp_startofpacket,
	adc_1_response_endofpacket   => adc1_resp_endofpacket
When I used the whole port ADC1_IN1 - ADC1_IN8 was no problem.
Now I want to use only one channel - ADC1_IN1 so I set only CH1 active in the core.
However I get the errors while compiling
Error (176310): Can't place multiple pins assigned to pin location Pin_7 (IOPAD_X0_Y37_N21)
Info (176311): Pin LED_CMD[5] is assigned to pin location Pin_7 (IOPAD_X0_Y37_N21)
Info (176311): Pin ~ALTERA_ADC1IN2~ is assigned to pin location Pin_7 (IOPAD_X0_Y37_N21)
Error (176310): Can't place multiple pins assigned to pin location Pin_8 (IOPAD_X0_Y36_N14)
Info (176311): Pin LED_CMD[6] is assigned to pin location Pin_8 (IOPAD_X0_Y36_N14)
Info (176311): Pin ~ALTERA_ADC1IN3~ is assigned to pin location Pin_8 (IOPAD_X0_Y36_N14)
Error (176310): Can't place multiple pins assigned to pin location Pin_10 (IOPAD_X0_Y36_N21)
Info (176311): Pin LED_CMD[7] is assigned to pin location Pin_10 (IOPAD_X0_Y36_N21)
Info (176311): Pin ~ALTERA_ADC1IN4~ is assigned to pin location Pin_10 (IOPAD_X0_Y36_N21)
Error (176310): Can't place multiple pins assigned to pin location Pin_11 (IOPAD_X0_Y35_N14)
Info (176311): Pin LED_CMD[8] is assigned to pin location Pin_11 (IOPAD_X0_Y35_N14)
Info (176311): Pin ~ALTERA_ADC1IN5~ is assigned to pin location Pin_11 (IOPAD_X0_Y35_N14)
Error (176310): Can't place multiple pins assigned to pin location Pin_12 (IOPAD_X0_Y35_N21)
Info (176311): Pin LED_CMD[9] is assigned to pin location Pin_12 (IOPAD_X0_Y35_N21)
Info (176311): Pin ~ALTERA_ADC1IN6~ is assigned to pin location Pin_12 (IOPAD_X0_Y35_N21)
Error (176310): Can't place multiple pins assigned to pin location Pin_13 (IOPAD_X0_Y34_N14)
Info (176311): Pin LED_TEST is assigned to pin location Pin_13 (IOPAD_X0_Y34_N14)
Info (176311): Pin ~ALTERA_ADC1IN7~ is assigned to pin location Pin_13 (IOPAD_X0_Y34_N14)
Error (176310): Can't place multiple pins assigned to pin location Pin_14 (IOPAD_X0_Y34_N21)
Info (176311): Pin LED_FLTn is assigned to pin location Pin_14 (IOPAD_X0_Y34_N21)
Info (176311): Pin ~ALTERA_ADC1IN8~ is assigned to pin location Pin_14 (IOPAD_X0_Y34_N21)
How can I resolve the problem?
Farabi
You may see this pin placement error in the Quartus® II software if you have enabled the Passive Serial (PS)configuration scheme and assigned the DCLK pin as a regular I/O pin. You can only assign the DCLK pin as a regular I/O pin if you selected the Active Serial (AS) configuration scheme.  When the Passive Serial configuration scheme is selected, the DCLK pin can only be used as a programming pin.
Resolution
Change to the Active Serial configuration scheme or remove the user signal location assignment to the DCLK pin.
please refer pin connection guideline.
regards,
Farabi
EEren
Sorry, I failed to understand. How DCLK pin related to ADC pins? And where do I change this configuration to Active Serial?
As I see in MAX10 Configuration Scheme may be only - Internal Configuration. It's an on board flash in the device.
EEren
Well... I found the answer - If you use bank 1A for ADC, you cannot use the bank for GPIO.
At least something stays rock solid - the support is traditionally lame on the forum.
Farabi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
regards,
Farabi
