21345 Discussions
How to write a 88bit*4096 ram in VHDL?
Hi everyone,
I am trying to write a 88bit*4096 RAM all in VHDL. I defined an array as RAM and use package to initialize it.
But there is an error when I compile it saying that *Error: Cannot convert all sets of registers into RAM megafunctions when creating nodes. The resulting number of registers remaining in design exceeds the number of registers in the device*
Can anybody shed some light on how to fix the error? Thanks. Following is
my VHDL code.
/* RAM */
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
library work;
use work.pack.all;
entity RAM_test is
port(
clk : in std_logic;
addr :in std_logic_vector(11 downto 0);
cs : in std_logic;
oe : in std_logic;
data_i: in std_logic_vector(87 downto 0);
data_o: out std_logic_vector(87 downto 0)
end RAM_test;
architecture Behavioral of RAM_test is
signal ram1 : RamType := MEM_INIT;
begin
process(clk)
begin
if(clk'event and clk = '1') then
if(cs = '0') then
if(oe = '0') then
data_o <= ram1(conv_integer(addr));
else
ram1(conv_integer(addr)) <= data_i;
end if;
end if;
end if;
end process;
end Behavioral;
/*Package*/
library IEEE;
package pack is
type RamType is array (0 to 4095) of std_logic_vector(87 downto 0);
constant MEM_INIT : RamType := (
/*content of RAM*/
end package pack;
The original warning message is preceeded by this important line
--- Quote Start ---
Info: RAM logic "ram1" is uninferred due to asynchronous read logic
--- Quote End ---
In my opinion, the analysis is incorrect. Quartus apparently doesn't like the nested if control signals. Try with this logically equivalent construct:
if cs = '0' and oe = '0' then data_o <= ram1(conv_integer(addr)); end if; if cs = '0' and oe = '1' then ram1(conv_integer(addr)) <= data_i; end if;
Quartus can be a bit tempremental in infering rams if you dont follow their coding guidlines properly. I have previously had problems (pre Q9, seems ok now) with some rams not being infered if there is no write-enable (some would work, some would not), and the response I got back was that "there is no write enable, so you're not following the coding guidelines).
With the OP could, I agree it should work, but I get the feeling it has built an asynchronous read mux in-front of the output register because of the if/else condition. It is always safer to completly separate your read and write logic, the way FvM suggested.
