Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
I/O Element
I want to know the number of I/O Element in user I/O.
CPLD:EPM570T144C5N
user I/O:116
Does All user I/O have I/O elemenst?
If it is possible, I want to use all user I/O as bidirectional I/O buffer(inout).
Highlighted
Hi there,
you should check the datasheet as
user I/O are pins available for your application but some are inputs only.
Highlighted
--- Quote Start ---
Hi there,
--- Quote End ---
Thank you for your answer.
I checked the device handbook.
but I don't know user I/O which is inputs only.
If it is possible, please let me know what is inputs only user I/O of EPM570T144C5N.
Highlighted
the pinout is defined in http://www.altera.com/literature/dp/max2/epm570.pdf
As there are no I/O pin defined as input only, the I/O as listed are bidirectional, some (e.g. the Clocksignals) are either dedicated clock signals or can be used as I/O (to be defined in QuartusII) - if you are fine with using the I/O regarding the number of signals to be connected, just use only the I/O...
