I am using Intel® Arria® 10 Transceiver PHY in a project which is later used for a non pci based protcocol, I am driving Tx_pma_elecidle signal at the tx pma side
but not able to detect rx_elecidle signal at the rx side in simulation (using Modelsim Altera) , even when i force tx_pma eelecidle the serial tx bit
is getting to hold a 'Z' value which seems to be okay ,so idea is within the RX circuit ,it will detect this 'Z' as rx_elecidle signal ,not sure whether there is a provision in simulation to detect it or not.
elecidle inference is set to zero ,and cdr is lock to reference ,
I have also attached a screenshot of the simulation in which tx and rx serial bits re connected via wire.
Please give some suggestions to move this up in simulation ..
As I understand it, you have some inquiries related to the RX electrical idle. To ensure we are on the same page, just would like to check with you on the following:
1. When you are referring to rx_elecidle, is it that you are referring to "pipe_rx_elecidle" output signal?
2. Just wonder if you are configuring the Native PHY to PCIe mode? For your information, the pipe_rx_elecidle is used only for PCIe configuration. It is not used for non-PCIe mode.
3. Please feel free to share with me your Native PHY .qsys file so that I can have a better understanding of your configuration.
Please let me know if there is any concern. Thank you.
Chee Pin
Hi ,
Thanks for replying.
Please find my answers below.
Answer :Yes , I am referring to pipe_rx_elecidle.
Answer :Agreed, My understanding to the config of the IP is that for PCIe protocols, there are particularly PIPE interfaces present , but there is an optional pcie signals also present that can be used with other protocols as well , by inferring these signals by the user, and pipe_rx_elecidle is one of them , so expectation is pipe_rx_elecidle will be one if tx_pma_force_elcidle is set to high ,
So in case this understanding is not correct , could you please help me with , how to detect elecidle signal in simulation for a non pcie based protocol like USB 3.0.
Answer : I am using Quartus prime 19.3, I have below attached(.ip) file to show you the configuration for the IP , I hope it will suffice for what you asked.
Please feel free to revert with more questions in case of any doubts
-Y.Arora
Sorry for the delay. Thanks for your clarification. For your information, pipe_rx_elecidle only work for PCIe configuration. For non-PCIe mode, the signal would not work. In other words, the pipe_rx_elecidle will not assert in non-PCIe mode when the tx_pma_force_elecidle is asserted. Sorry for the inconvenience.
Regarding your inquiry on how to detect elecidle signal in simulation for non PCIe mode ie USB 3.0, sorry as I do not have much insight into this and could not further comment on this. If you would like to further engage our Design Service partner for USB 3 related IP or design in A10 devices, you may try further look into the following link to see if it helpful. Note that there will be charges.
You may also visit the following and search for "usb" to find other USB related partners:
