Programmable Devices
20641 Discussions
I am not getting expected response in Modelsim
Dear all,
Could someone please have a look at my code and say what is wrong in it.
entity pinconfig is
port(
pins :in std_logic_vector (13 downto 0):="00000000000000";
signalsin :inout std_logic_vector (35 downto 0);
signalsout :inout std_logic_vector (35 downto 0)
end pinconfig;
architecture behav of pinconfig is
component iobuffer
PORT
datain : IN STD_LOGIC_VECTOR (35 DOWNTO 0);
oe : IN STD_LOGIC_VECTOR (35 DOWNTO 0);
dataio : INOUT STD_LOGIC_VECTOR (35 DOWNTO 0);
dataout : OUT STD_LOGIC_VECTOR (35 DOWNTO 0)
end component;
type c is array (0 to 35, 0 to 2) of integer range 0 to 35;
signal config : c :=
((0,0,1),(1,1,1),(2,2,1),(3,3,0),(4,4,3),(5,5,0),(6,6,3),(7,7,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3),
(12,12,3),(13,13,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,18,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3),
(24,24,3),(25,25,3),(26,26,3),(27,27,0),(28,28,3),(29,29,0),(30,30,0),(31,31,0),(32,32,0),(33,33,0),(34,34,0),(35,35,3));
--signal config : c :=
--((0,27,3),(1,29,3),(2,31,3),(3,5,0),(4,4,3),(5,4,0),(6,13,3),(7,18,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3),
--(12,12,3),(13,6,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,7,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3),
--(24,24,3),(25,25,3),(26,26,3),(27,0,0),(28,28,3),(29,1,0),(30,33,0),(31,2,0),(32,34,0),(33,3,0),(34,35,0),(35,32,3));
--config(x,x,0) = out (fpga => gpio)
--config(x,x,1) = in (fpga <= gpio)
--config(x,x,2) = constant low (pin)
--config(x,x,3) = high-Z (pin)
signal temp: std_logic_vector (35 downto 0);
I Used 2 different pin configurations. Both failed
thanks
You dont say what the problem is?
You Didnt post the whole code?
your picture is far too small.
Not much we can say until you fix the above.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity pinconfig is
port(
end pinconfig;
component iobuffer
PORT
end component;
((0,27,0),(1,29,0),(2,31,0),(3,5,0),(4,4,3),(5,4,0),(6,13,3),(7,18,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3),
--((0,0,0),(1,1,0),(2,2,0),(3,3,0),(4,4,3),(5,5,0),(6,6,3),(7,7,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3),
--(12,12,3),(13,13,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,18,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3),
--(24,24,3),(25,25,3),(26,26,3),(27,27,0),(28,28,3),(29,29,0),(30,30,0),(31,31,0),(32,32,0),(33,33,0),(34,34,0),(35,35,3));
begin
process (pins)
begin
--pins(13 downto 8) = mapped to
--pins(7 downto 2) = mapped from
--pins(1 downto 0) = out, in or high-Z
config(to_integer(unsigned(pins(13 downto 8))),1) <= to_integer(unsigned(pins(7 downto 2)));
config(to_integer(unsigned(pins(13 downto 8))),2) <= to_integer(unsigned(pins(1 downto 0)));
end process;
process (signalsin, signalsout)
begin
case config(0,2) is
when 0 => temp(config(0,0)) <= signalsin(config(0,1));
when 1 => temp(config(0,1)) <= signalsout(config(0,0));
when others =>
end case;
case config(1,2) is
when 0 => temp(config(1,0)) <= signalsin(config(1,1));
when 1 => temp(config(1,1)) <= signalsout(config(1,0));
when others =>
end case;
case config(2,2) is
when 0 => temp(config(2,0)) <= signalsin(config(2,1));
when 1 => temp(config(2,1)) <= signalsout(config(2,0));
when others =>
end case;
case config(3,2) is
when 0 => temp(config(3,0)) <= signalsin(config(3,1));
when 1 => temp(config(3,1)) <= signalsout(config(3,0));
when others =>
end case;
case config(4,2) is
when 0 => temp(config(4,0)) <= signalsin(config(4,1));
when 1 => temp(config(4,1)) <= signalsout(config(4,0));
when others =>
end case;
--here i have to write code for all 36bpins, but i cannot write a reply to you more than 10000
when others =>
end case;
end process;
process (temp)
begin
case config(0,2) is
when 0 => signalsout(config(0,0)) <= temp(config(0,0));
when 1 => signalsin(config(0,1)) <= temp(config(0,1));
when 2 => signalsout(config(0,0)) <= '0';
when others => signalsout(config(0,0)) <= 'Z';
end case;case config(1,2) is
when 0 => signalsout(config(1,0)) <= temp(config(1,0));
when 1 => signalsin(config(1,1)) <= temp(config(1,1));
when 2 => signalsout(config(1,0)) <= '0';
when others => signalsout(config(1,0)) <= 'Z';
end case;case config(2,2) is
when 0 => signalsout(config(2,0)) <= temp(config(2,0));
when 1 => signalsin(config(2,1)) <= temp(config(2,1));
when 2 => signalsout(config(2,0)) <= '0';
when others => signalsout(config(2,0)) <= 'Z';
end case;case config(3,2) is
when 0 => signalsout(config(3,0)) <= temp(config(3,0));
when 1 => signalsin(config(3,1)) <= temp(config(3,1));
when 2 => signalsout(config(3,0)) <= '0';
when others => signalsout(config(3,0)) <= 'Z';
end case;case config(4,2) is
when 0 => signalsout(config(4,0)) <= temp(config(4,0));
when 1 => signalsin(config(4,1)) <= temp(config(4,1));
when 2 => signalsout(config(4,0)) <= '0';
when others => signalsout(config(4,0)) <= 'Z';
when others => signalsout(config(35,0)) <= 'Z';
end case;
end process;
end behav;
Have a loot and help me
What ever the configuration I use, I am not getting any response in modelsim waves . I compiled with zero errors in Quartus II
Picture is still too small
You didnt say what this code is meant to do, or whats wrong?
Commenting on what code you did post - it is pretty bad - big arrays full of constants with no explanations of what they are. Especially when you didnt say what the code does or whats wrong with the code.
these are the config rules I used. And this program is pinconfiguration of the FPGA TO GPIO and GPIO TO FPGA. ALTBIO (Bidirectional buffer) I used here. And I am trying to develop the module for FPGA to configure faster and run faster. But I could not able to see expected output in model sim.
Did you write a testbench? how are you driving the design?
I wrote complete program in Quartus II and Here I compile and.. Later I used tools ..there I have option RTL simulation this means Modelsim.
Try to add your screenshots in a picture format that isn't reduced to unreadable garbage by the board software, e.g. .png. Check the picture after posting, retry if necessary.
Are you trying to tell that bidirectional pin's are not responding after forcing input to it?
If yes, in test bench while changing config you should set the bidirectional pins to noforce.
can you post a portion of test bench code?
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Hi Sasi,
Your simulation is not acting as you would expect from your source code. This is a clear hint for missing signals in a process sensitivity list.
After a brief look on your posted code, your second and third process is missing "case_config" in its process sensitivity list.
If you have a look at the synthesis report, you should find a warning about missing signals in the sensitivity list as well.
Best,
Jusuf
Hai Raj,
I am not writing test bench . I directly compile through Quartus RTL Simulation.
