20405 Discussions
I have a design code wrote in VHDL. I'm planning to test the code using system verilog i.e to debug the code,to perform coverage analysis,functional coverage etc.which tool support this kind of testing?
mmn001
I'm a beginner of system verilog programming, i want to do verification of vhdl codes using system verilog but very much confused with which tool to use,how to use.need some guidelines..please help
Vicky1
You can use Questasim for verification purpose, which allows you to check coverage analysis. you can also check the EDA Playground.
There are few websites/Forums which will help to you for verification like,
http://www.testbench.in/
https://www.verificationguide.com/p/home.html
https://verificationacademy.com/
https://www.chipverify.com/
Please help me to close this case.
Vicky
