20257 Discussions
I have a design that uses 10M16SAU169I7G. i noticed that every time I flash it, many I/Os (if not all of them) are going high, I even have a led connected that lights up.
ISh
i have done a blank check and even erased the device again, but nothing changes, still the device has many high voltage I/O's.
my bank voltage is 3.3V. please advice why this happens and why the I/O's aren't Tri-stated?
SreekumarR_G_Intel
can you check the configuration setting in the quartus ? There is options to enable / disable the Trisate . Also what you mean by all the IOs are not high state ? Can you clarify the same ? Thank you , Regards, Sree
ISh
​configuration setting in the quartus is irrelevant because I am talking about a blank max10, a max10 that comes from the factory.
I assume it is the same as an erased one.
why aren't the output of the device at tri-state on a blank component?
thank you,
Itai
a_x_h_75
New Contributor III
Blank, unprogrammed parts all have tri-state I/O with weak pull-ups.
Cheers,
Alex
SreekumarR_G_Intel
Hello Alex ,
Can you kindly point out in datasheet where it is mentioned ?
Thank you ,
Sree
a_x_h_75
New Contributor III
https://www.intel.com/content/www/us/en/programmable/documentation/mcn1397700832153.html#mcn1397811237452
Table 17:
"Value of I/O pin (dedicated and dual-purpose) pull-up resistor before and during configuration, as well as user mode if the programmable pull-up resistor option is enabled"
Cheers,
Alex
ISh
Thank you for the answer and pointing on the datasheet,
Though, I see that it is possible to change User I/Os weak pull up during configuration: https://www.intel.com/content/www/us/en/programmable/documentation/sss1393988509894.html#sss1426059991604 through changing the ICB settings.
Is it possible to configure the weak pull up also when the max10 is not configured? (for example , configuring the icb settings and then erasing the device)
Thanks, Itai.
a_x_h_75
New Contributor III
This only affects the device during configuration. As soon as you erase the part these settings will have no effect.
Cheers,
Alex
