21500 Discussions
I have a problem with program. when i download a sof file with jtag,it successd in case of msel value 001(ps/fpp mode).But if msel set to 011(as mode),it fail,error ID:209014.
SHuai
The chip is 10AS016E3F27.
In ps/fpp mode,jtag detect 2 device,10AS016E3 and SOPVHPS
In as mode,jtag detect 1 device,10AS016E3
I have connect nCONFIG,nSTATUS,CONF_DONE through a 10 k resistor to VCCPGM,nCE to GND.
How should i solve the problem.
Thank you!
ShafiqY_Intel
Hi SHuai,
The reason of this error is the CONF_DONE pin in the device did not go high at the end of configuration.
Here are some factors of this error:
  • Communications cables not securely connected
  • Incorrect device selected
  • No power to target system
  • Device nCE pin not connected to GND
Here some workaround you can try:
  • Remove the SD card and reinsert it in the bard farm machines
  • Can you kindly try to reduce your TCK frequency to 6 MHz (default value)?
Below link is the command to change TCK frequency (on page 14= 2.8. Changing the TCK Frequency) https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf#page=14
I hope this will help.
SHuai
I had reduce TCK frequency to 6 MHz but the problems remain​.
Thanks​
ShafiqY_Intel
Hi SHuai,
May I know the status of this issue?
SHuai
The problem has been solved.
The hardware engineer made a mistake that there are differences between boards and schematic design.
when I set msel value 011,actual setting is 101.It is a wrong configuration.
Thanks​
ShafiqY_Intel
Hi SHuai,
I am glad to hear that the issue is resolved.
I will close this thread. If you have further question, please submit a new forum thread.
