21593 Discussions
I need to connect several IntelRealSense D435 cameras from the same application in C#. I would like to retrieve the connection information, but I don't succed and can't find an example in C#.
tchen169
I've been using the Intel RealSense D435 camera for a few months, I now need to be able to connect several cameras on a single application. To do this I would need the connection information of the cameras I gess, so that I can then launch a thread per camera. I had already tried to retrieve this connection information, so that I could manage the disconnection and reconnection of the camera while the program is running. But I hadn't succeeded, for lack of example in C#, which is the language I use. I found this perfect C++ exemple at the last of the topic : https://forums.intel.com/s/question/0D50P0000490SC4SAM/d435-streams-work-once-then-crash?language=en_US But don't succed to translate it into C# and use the function that are used in the example. May be some one already do something like that in c# ?
Please let me know if you need any other information, and thanks in advance!
KeenYewL_Intel
Hi tchen169, you reached the FPGA forum site, I'm afraid we don't have the expertise to answer realsense question. Perhaps you can try the realsense forum here: https://support.intelrealsense.com/hc/en-us/community/topics
tchen169
Thanks. Yes I know this forum, but why the topics I link is on this forum ?
