Programmable Devices
20703 Discussions
I write DFh to address 0 on "EPM240T100C5N" by the programmer, security is imposed on the CFM area and only 00 can be read. Is it possible to explain why security is applied even though Security bit is not set ?
TTsuj6
Nooraini_Y_Intel
Hi TTsuj6,
How did you generate the .pof file? Are you using Quartus programmer to program the .pof file into the EPM240T device CFM memory block ? Or are you using your own custom tools/programmer to program the EPM240T device CFM memory block?
Nooraini
TTsuj6
Hi NYusof,
I used my own custom programmer to program the EPM240T device CFM memory block.
I didn't use pof file.
TTsuj6
Nooraini_Y_Intel
Hi TTsujo6,
Did you perform erase operation first before program operation? Make sure all the power supplies are correctly powered up before any operation. Did you power cycle the EPM240 device after program the CFM before perform the verification process? Please do not perform power cycle between any processes. As explain in the MAX II device handbook under Chapter 3: JTAG and In-System Programmability, the programming sequence should be Power up ->Enter ISP ->Check ID->Erase ->Program ->Verify -> Exit ISP ->Power down.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max2/max2_mii5v1.pdf
How did you get/generate this DFh data? If you are using your own programmer, then you should be referring to the .pof or .svf file for the correct data that need to be write into the CFM memory block. You should convert the .pof file into a .svf file. The .svf file contain all the correct programming sequence and data that user can use to program the CFM + UFM. You can refer to the how to video on the steps to generate .svf file:
https://www.youtube.com/watch?v=L4R2NKekttw
Nooraini
Nooraini_Y_Intel
You may also refer to the attached document on the example .svf file. Thank you.
Nooraini
