Which one should be used for 1.8V eMMC IO assignment?
IO standard: 1.8V, SSTL-18 class i or class ii, HSTL-18 class i or class ii???
May I ask what is eMMC?
Thank you
eMMC is managed NAND.
Please see attached datasheet.
That document is marked WESTERN DIGITAL CONFIDENTIAL. You should NOT be posting it here.
Intel should NOT read it AND the webmaster should DELETE it ASAP.
You should be asking Western Digital what signaling levels to use for their device.
How to delete it ?
Or how to contact web master?
I did not find a way.
Looks like the confidential data sheet upload has been deleted.
For your original question I would ask Western Digital for their interface level recommendation.
I will close this case since no support will be needed from here.
Thank you
