How to instantiate FPLL of cyclone 10 GX device. I don't see this in the PLL IP list. According device overview datasheet 10CX105 there are 6 IOPLL.
According the compilation report there are only 4 IOPLL but 8 FPLL
Regards, Jan
Hello Jan ,
i am bit confused on your requirement , As of I now i understood cyclone 10 GX FPLL used as the XCVR (Transceiver) PLL whereas IOPLL's are used for the FPGA fabric.
About the count difference would it possible to share the screen shot of Compliation report and Datasheet referennce number where it mentioned as 6.
Thank you ,
Sree
Hello Snee
I find out that the number of PLL depends on the number of banks cq device pin count
484 pins device has 4 IOPLL (4 banks) 672 pins has 5 IOPLL (banks) and 780 pins has 6 IOPLL (banks).
In the device list however all has 6 see enclosed screenshot and compilation reports.
Also in the documentation i cannot find that number of pll is dependent on package.
Regards, Jan
Hello Jan,
Hope you safe there,
Just would like to let you know i raised the concern to the internal team . will let you know as soon i get the update.
Sree
Hello Jan,
Can you check the 20.1 pro ?
Thank you ?
Sree
