Hello everybody.
I am working on a EPF10k20RC240-4 FPGA. I have a few outputs with enables. these output connect together in a connecting point. Now I want to get my favourite output by selecting it via setting the enable. How can get it? In the oder word, I want to have a tristate ('0','1','z') array with one common output. The common output value show the value of the selected output via it's enable. All the best Bahman.Link Copied
do you have any code yet? and what language are you trying to use?
--- Quote Start --- do you have any code yet? and what language are you trying to use? --- Quote End --- Hello. I have some code about it in VHDL,but I am not sure of it. the code is following. Do you have a better code than mine? Thanks alot. ---------------------------- library ieee; use ieee.std_logic_1164.all; entity tristate_dr is port( d_in: in std_logic_vector(7 downto 0); en: in std_logic; d_out:out std_logic_vector(7 downto 0) ); end tristate_dr; architecture behavior of tristate_dr is begin process(d_in, en) begin if en='1' then d_out <= d_in; else d_out <= "ZZZZZZZZ"; end if; end process; end behavior;
do you have one external output (a pin) for all output signals or do you have one output pin for each output and connect them together outside of your device ? If you want to connect the outputs together internally (and route them to one output pin) you should not do this with tri-state signals. You should use a mux instead.
