21462 Discussions
Initial value setting errir
Er7Cho1gU
Hello:
    I'm new in verilog.  Hopping that it's not a very stupid problem.
    I'm tring to buid a FSM system using register "state" to perform the state now.  There is no error hint or any functional problem on FSM insted of the initial problem on reg "state".  The waveform shows that reg "state" keeping high at the begining, untill  the stop signal arrives.  Alought I had setting the initial value at begin, I can't fix it and I have no idea what could I do.  Hopping that someone can help me.
Here is my code:
module state(start,stop,state);
input start,stop;
output reg state;
initial state = 1'b0;
always@(posedge start or posedge stop)begin
if(start == 1) state = 1;
else if(stop == 1) state = 0;
else state = state;
end
endmodule
sstrell
Your waveform does not show what you are saying in your post.  I just see state as unknown or don't care throughout the sim.
If you are really trying to build an FSM, this is not the way to do it.  You need two processes: one that is usually a clocked process (you have no clock here) that handles state transitions, usually based on input signals or the current state and one process that handles what the outputs should be when in a particular state.  It's unclear what you're trying to do here.
ak6dn
Valued Contributor III
I agree with @sstrell
For reference, here is what I see running your code ...
module test;
    initial
	begin
	$timeformat(-9, 0, "ns", 12);
	$dumpfile("test.vcd");
	$dumpvars(2,test);
	end
    reg start = 0;
    reg	stop = 0;
    wire state;
    initial
	begin
	#1000 start = 1;
	#100  start = 0;
	#300  stop = 1;
	#100  stop = 0;
	#500  $write("\n");
	$finish;
	end
    always @(start or stop or state)
	begin
	$write("%t start=%b stop=%b state=%b\n", $time, start, stop, state);
	end
    state u1 (start, stop, state);
endmodule // test
module state (start,stop,state);
    input start, stop;
    output reg state;
    else state = state;
    end
endmodule
and the result ...
GPLCVER_2.12a of 05/16/07 (Cygwin32).
Copyright (c) 1991-2007 Pragmatic C Software Corp.
  All Rights reserved.  Licensed under the GNU General Public License (GPL).
  See the 'COPYING' file for details.  NO WARRANTY provided.
Today is Wed Oct 12 11:17:09 2022.
Compiling source file "./test.v"
Highest level modules:
test
         0ns start=0 stop=0 state=0
      1000ns start=1 stop=0 state=0
      1000ns start=1 stop=0 state=1
      1100ns start=0 stop=0 state=1
      1400ns start=0 stop=1 state=1
      1400ns start=0 stop=1 state=0
      1500ns start=0 stop=0 state=0
Halted at location **./test.v(24) time 2000 from call to $finish.
SyafieqS
Hi Lin,
May I know if previous reply able to solve you issue?
SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 10/10 survey
