21602 Discussions
Inputs have current strength field in pin planner tool -- does it matter?
FBels
In the Quartus Pin Planner ​ tool the Node Name list has a column Current Strength that has an entry 8mA (default) for Input pins.  Does that matter?  What is the default pullup state for inputs if not specified?
Vicky1
Hi Fred, For default I/O setting,you need to refer the respective device handbook. Refer the below KDB link, https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/rd08292012_329.html Regards, Vikas
