Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Installation problem of Quartus II on Debian
Hi, I'm using Debian Wheezy and when running the "11.1sp2_259_quartus_free_linux.sh" file I get this:
Starting GUI. If nothing shows up, or you don't have an X display, run: ./setup --help for commandline usage. NOTE: All output has been redirected to /tmp/altera_setup.log.W8lGSZjJBL
and this is the altera_setup.log.W8lGSZjJBL
./setup: line 61: /home/andres/Programs/11.1sp2_259_quartus_free_linux/altera_installer/bin/altera_installer_cmd: No such file or directory
What do I do? Any help would be appreciated, thank you.
Highlighted
Re: Installation problem of Quartus II on Debian
--- Quote Start ---
What do I do?
--- Quote End ---
Change Linux distro?
Installation under Ubuntu 11.10 and Centos 6.2 works fine (after a little tweaking).
Cheers,
Dave
Highlighted
Use the debian guide at the alterawiki:
www dot alterawiki dot com/wiki/Quartus_for_Debian_Wheezy
I was able to get it to work with debian wheezy and Modelsim/Quartus 12.0 SP2.
Change the setup file shebangs to# /bin/bash and run them with ./setup --gui from a terminal.
Highlighted
install flashplugin first for gui
install libc6-i386 first for 64bit linux
it's work for me
--- Quote Start ---
--- Quote End ---
Highlighted
I need 5 posts to post a hyperlink how frustrating!!! 😞 see my next post
Highlighted
CHeck this out: http://www.alterawiki.com/w/index.php?title=quartus_for_debian_wheezy
I found this on this forum its a complete guide for installing QuartusII on Debian by Hannes
