20242 Discussions
Intel Arria 10 GX FPGA (DK-ACB-10AX1152AES) compatible with Dell R540 ?
JVice2
Is there any constraint installing the FPGA DK-ACB-10AX1152AES in a Dell R540. The installation guide refers to the Dell R640 as the minimum validated platform of DELL. Would be posible to install it in R540 ?. The power supply of this server is arround 700w.
RichardTanSY_Intel
Recommend to install in Dell R640 as it has been validated. Using R540 or lower spec is not recommended as it may cause device misbehaving.
