I have a customized design which I have routed a NVRAM to SPI pin of HPS side.
Now the software team wants to access NVRAM like a flash. So I'm thinking to use generic flash controller ip core in FPGA to control it. I know it's possible to loan pins from HPS to FPGA.
The issue here is :
The generated conduit signals supposed to connect to FPGA are only unidirectional, see
._hps_io_gpio_inst_LOANIOXX Bi-direction to top level pin assignment
._h2f_loan_io_in Out to FPGA logic
._h2f_loan_io_out In to FPGA logic
._h2f_loan_io_oe In to FPGA logic
But the generic flash control ip has bidirectional IO for data transfer. It seems I can not connect them together. Is there any solution for this? If not, then I have to redesign the board to use FPGA pin instead.
Thank you very much for your time.
Any response/reply is appreciated.
Mingyuexin
May I know the Quartus version you are working with?
Also, which board are you referring to? Is It Cyclone V SoC, Arria 10 SoC etc
Thank you very much for the response.
I'm working with Quartus Prime standard 18.1.
My board is Cyclone V SOC.
Best regards
Mingyuexin
Do you have any solution or suggestions on this?
With best wishes
Mingyuexin
Accord to our Cyclone V SoC Device Design Guidelines, the recommend peripherals that the HPS dedicated IO with loaner are: QSPI, NANDx8,eMMC, SD/MMC, UART,USB, EMAC
NVRAM is not entirely supported. But you may check our video tutorial on how to initiate the example of HPS loaner IO using Qsys/Platform Designer here:
I have a question. For Arria10 devices, I don't see the LOANIO option, and my quartus version is 18.1
Sorry I have never used Arria 10, I do not know.
Best regards
Mingyuexin
Hi Mingyuexin,
Want to ask this question, have you found the answer? I also want to know this part.
Thank you.
Sorry to see your question this late.
We redesigned the hardware to use FPGA fabric to communicate with the flash.
With best wishes
Mingyuexin
