I have a design which will use gigbit transceivers, I wonder is ther an IP I can use to do Bit Error Ratio Tester to verify whether the hardware is in good shape or not?
Thanks in advance.Link Copied
Use the Transceiver Toolkit ... its part of the Quartus GUI
http://www.altera.com/products/software/quartus-ii/transceiver/swf-transceiver-toolkit.html http://www.altera.com/support/examples/on-chip-debugging/on-chip-debugging.html Basically the examples create a Qsys system with a PHY, a PRBS pattern generator and a checker. You can then the Quartus Transceiver Toolkit GUI to control the Qsys system and generate bath-tub plots, etc. Cheers, Dave- Mark as New
--- Quote Start --- Use the Transceiver Toolkit ... its part of the Quartus GUI http://www.altera.com/products/software/quartus-ii/transceiver/swf-transceiver-toolkit.html http://www.altera.com/support/examples/on-chip-debugging/on-chip-debugging.html Basically the examples create a Qsys system with a PHY, a PRBS pattern generator and a checker. You can then the Quartus Transceiver Toolkit GUI to control the Qsys system and generate bath-tub plots, etc. Cheers, Dave --- Quote End --- Thanks very much, Dave. Now Altera website is in maintenance which I can't check them now. It seems the PRBS pattern generator and checker, these two IPs are not in Quartus II as default, we have to download them and install, right? Thanks.
--- Quote Start --- It seems the PRBS pattern generator and checker, these two IPs are not in Quartus II as default, we have to download them and install, right? --- Quote End --- They are standard components. Open Qsys, type "Pattern" in the IP Catalog search box, and you'll see the Avalon-ST pattern generator/checker components. There are several components. Read the documentation for each to determine which ones you want. Better yet, just open the examples at the link I provided above and see what they used (once the Altera site comes back online). Cheers, Dave
