21611 Discussions
Issues on <alt_interrupt.h> header file
CAlex
New Contributor II
I include the <alt_interrupt.h> in order to use the interrupt on HPS form fpga,
I got the following error
which I believe from this block in <alt_interrupt.h>:
Could you please tell me how to solve this problem?
reguards
aikeu
Hi CAlex,
I am not able to see the error from the pictures(blur) that you have attached.
Can show me the error again?
Aik Eu
CAlex
New Contributor II
Ok,It's on the first picture if wouldn't mind click it.
It says: on src/hwmgr/alt_interrupt.c(951) error: undefined reference to "__cs3_interrupt_vector"
aikeu
Hi CAlex,
May I know what document which you follow to build your project?
Anyway, I think it might be related to you make file:
In the Makefile change "CROSS_COMPILE := arm-none-eabi-" to "CROSS_COMPILE := arm-altera-eabi-".
Aik Eu
CAlex
New Contributor II
I followed the DE10 standard User Guide in SOC FPGA chapter,
I copied the example's makefile and made some other rules to link all the resources in my Makefile document.
And could I ask is there any compile tools need to be download to use altera- eabi?
Thank you for your reply.
reguards.
aikeu
Hi CAlex,
I was looking into this documention previously which relates to some related software tools involved in the steps:
https://github.com/arktur04/cyclone-v-baremetal
Anyway I suggest you can follow the newer build steps in refering to the cyclone V timer example which consider the alt_interrupt.h (Running Cyclone V Timer Example):
https://www.rocketboards.org/foswiki/Documentation/HWLib
The example code as below:
https://github.com/altera-opensource/intel-socfpga-hwlib/blob/master/examples/CVAV/Altera-SoCFPGA-HardwareLib-Timer-CV-GNU/main.c
Aik Eu
CAlex
New Contributor II
I read throught the link you gave and tried a little but it seems didn't work on Liunx.
The example you gave I assume is with the GHRD yet can't work as well.
Could you provide timer interrupt examples work on linux?
I didn't find any on intenet.
Thank you for help
reguards.
aikeu
Hi CAlex,
The alt_interrupt only meant for baremetal application.
As for any linux example I think this is the one you will be looking into:
https://github.com/altera-opensource/linux-refdesigns/blob/master/pio-interrupt/gpio_interrupt.c
Aik Eu
CAlex
New Contributor II
Thank you, I'll start research on that.
reguards.
aikeu
Hi CAlex,
I will close this thread if no further question at the moment. Do consider re-open a new thread if there is.
Aik Eu
aikeu
Hi CAlex,
I am closing this thread for now. Feel free to provive a good feedback If you happened to receive a survey.
Aik Eu
