Recently the script for signing the bitstream of an aocx file has started failing. By failing I mean when I run "..linux64/libexec/sign_aocx.sh" with the proper arguments it runs halfway, stopping before the first 'aocl binedit' command. This pastebin shows which echo statements happen or happened. The reason this is an issue is that when I try and run a program with this half finished aocx it seg faults on the function clCreateProgramWithBinary.
A few things make this very confusing.
Some info about the system
Quick note for the point about 'instances' or 'users'. I don't really know what I'm talking about or that means, I just know what I SSH into, and log in. If I need to clarify this I can go find out the specifics
Could anyone give any suggestions as to a fix?
Keith
Hi ,
Please let us know whether the issue is still observed and whether it is seen in a cloud environment or not.
Thanks and Regards
Anil
For more complete information about compiler optimizations, see our Optimization Notice.
