Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Jtag Errors -> Reducing JTAG frequency on Arria V / Terasic USB blaster ?
I use Jtag to program and debug an Arria V: 5AGXBB1D4F40C5 (nios programming, check nios printf(), signaltap II, ...) on a custom board.
I am using Quartus 16.0.0 build 211 Standard Edition on w7 x64. with a Terasic USB blaster (usb-blaster-B on pcb).
I have some errors:
--- Quote Start ---
Error (12852): Data integrity error is detected during JTAG communication. The SignalTap result is not trustworthy. Please check the JTAG chain.
--- Quote End ---
So I tried to lower the Jtag frequency to get better results but I can't:
--- Quote Start ---
$ jtagconfig --setparam "USB-Blaster [USB-1]" jtagclock 6M
No parameter named jtagclock
--- Quote End ---
maybe it is not possible regarding this link:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd11142008_293.html
Is there any solution to enhance the jtag connection?
Thanks in advance.
