21587 Discussions
Jtag chain broken
TabetS
When the Jtag debugger is used for debugging, a TDI problem is displayed, and the following information is displayed  "Jtagconfig -d".
Unable to read device chain - JTAG chain broken
Captured DR after reset = (0343B0DD)
Captured IR after reset = ()
Captured Bypass after reset = (0)
Captured Bypass chain = ()
How to solve this problem. Thanks
Labels (2)
Farabi
To start debug, we need more information from you:
  1. Is this board you designed? or is this devkit?
  2. how many boards you see this failure?
  3. have you change the USB Blaster II programming cable and see if this can solve the issue?
regards,
Farabi
NurAiman_M_Intel
Can you also share the screenshot of the error?
Aiman
NurAiman_M_Intel
Do you have any update for this case?
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
