21420 Discussions
Jungo WinDriver Installion on UBUNTU
I want to develop Driver for PCIe on Ubuntu, for that I am trying to install Jungo Windriver on Ubuntu.
I have downloaded WD1221LNX86_64.tgz from Jungo and extracted it.(http://www.jungo.com/st/pr (http://www.jungo.com/st/products/windriver/wd_linux/)).
I follow the steps as per instructions on http://www.jungo.com/st/suppor (http://www.jungo.com/st/support/windriver/how_to_install/).
After running ./configure command there is error of WinDriver/redist/.tmp_driver/.
checking target... LINUX.3.16.0-46-generic.x86_64
checking for regparm kernel option... find: `/home//desktop/old_wd/windriver/redist/.tmp_driver/.tmp_versions': no such file or directory
checking for right linked object... windrvr_gcc_v3.a
checking for modpost location... /usr/src/LINUX/scripts/mod/mod
configure.wd: creating ./config.status
config.status: creating makefile.wd.kbuild
Also when I check Windriver directory /home/Desktop/WinDriver/redist/LINUX.3.16.0-46-generic.x86_64 there is no windrvr1221.ko file which is used to build
Windriver kernal..
please help me to resolve......
Not really an 'Altera' related issue... is it? Look to Jungo for help, maybe?
Cheers,
Alex
I have strugled with the driver and ended up not using ubuntu.
--- Quote Start ---
Windriver kernal..
--- Quote End ---
You can ignore this message, as this is only a warning.
After running configure command, you should run 'make'. See WinDriver installation instructions in windriver user manual (http://www.jungo.com/st/support/documentation/windriver/12.3.0/wdpci_manual.mhtml/wd_install_process.html#wd_linux_installation
You can also open a support ticket at http://techsup.jungo.com and WinDriver support team will assist you to install the driver on Linux.
