21594 Discussions
LVDS resistor termination in Cyclone III
I have a design with 2 FPGA (EP3C16F484) linked together with a set of LVDS line.
I use pins in bank 1, 2, 5 an 6.
Should I place a 100ohms resistors on the receiver side, or is it included in the FPGA?
(I have search for this information in datasheet. I have undersand there is no need for resistor on transmitter, but nothing really accurate on receiver side)
--- Quote Start ---
--- Quote End ---
Yes. The hardware manual is clear about this point.
Thanks for answering.
Please could you told me where the hardware manual is clear (is that on page 7-27)?
I have miss something... and I want to read it carefully.
--- Quote Start ---
--- Quote End ---
Page 6-20 of the cyclone III handbook:
The LVDS standard does not require an input reference voltage, but it does require a
100-Ω termination resistor between the two signals at the input buffer. An external
resistor network is required on the transmitter side for top and bottom I/O banks.
Page 7-8 of the cyclone III handbook:designing with lvds
Cyclone III device family I/O banks support LVDS I/O standard. The left and right
I/O banks support true LVDS transmitters. On the top and bottom I/O banks, the
emulated LVDS transmitters are supported using two single-ended output buffers
with external resistors. One of the single-ended output buffers is programmed to have
opposite polarity. The LVDS receiver requires an external 100-Ω termination resistor
Success, Ton
Hello I am Miguel and working on FPGAs for 4 years.
I recently found an doubt that I ant to confirm:
All IO banksfrom Cyclone 3 have dedicated LVDS RECEIVERS and only 1, 2, 5 and 6 have DEDICATED LVDS Transmitters right???
Thank you in advance.
--- Quote Start ---
Page 6-20 of the cyclone III handbook:The LVDS standard does not require an input reference voltage, but it does require a
Success, Ton
--- Quote End ---
--- Quote Start ---
--- Quote End ---
Right. Best explained in C-III Device handbook chapter 7: http://www.altera.com/literature/hb/cyc3/cyc3_ciii51008.pdf
