Programmable Devices
21271 Discussions
Life Cycle status.
Componentengineer
Hi Team,
       Can you please provide the life cycle status of below following MPN's.
1.AT80571PH0723ML
2.AT80614005073AB
3.AU80610006225AA
4.CM8066201920404 SR2L6/LGA1151
5.EE82802AB
6.EN80C31BH1
7.EP2AGX125DF25C5G
8.EP2AGX125EF35C5G
9.EP2AGX190EF29C6G
10.EP2AGX65DF25C5G
11.EP2AGX65DF29C5G
12.EP2AGX95EF29C5G
13.EP2C15AF256C6N
14.EP2C5T144C8N
15.EP3C10F256C8N
16.EP3C16F484C8N
17.EP3C40F484C6N
18.EP3C40F484C8N
19.EP3C40F780C6N
20.EP3C80F484C8N
21.EP3SL200F1152C2G
22.EP3SL340H1152C2G
23.EP4CE10F17C8N
24.EP4CE6F17C8N
25.EP4CGX22CF19C8N
26.EP4SGX230FF35C2N
27.EP4SGX230FF35C2NES
28.EP4SGX230FF35C2XG
29.EP4SGX360FF35C2XG
30.EPCQ64ASI16N
31.EPM1270F256C5N
32.EPM1270T144C3N
33.EPM2210F256C5N
34.EPM2210F256C7N
35.EPM240T100C5N
36.EPM570F100C5N
37.EPM570F256C5N
38.EPM570GF256C5N
39.EPM570T100C5N
40.EPM570T144C4N
41.EW31244
42.EX1AV
43.FH8065301487717 SR3UT
44.FH8070304243832
45.FH8070304243833
Ajithkumar
givememessage
New Contributor II
what do you want to do
NazrulNaim_Intel
Good day
Thank you for reaching out. I'm Nazrul Naim looking into your issue and allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
NazrulNaim_Intel
Sorry for the delay. Below the information needed for the devices. This tech support is focusing on Intel FPGA family. Unfortunately, we can't support any issue that is not related to FPGA.
1.   AT80571PH0723ML
2. AT80614005073AB
3. AU80610006225AA
4. CM8066201920404 SR2L6/LGA1151
5. EE82802AB
6. EN80C31BH1
7. EP2AGX125DF25C5G - Active
8. EP2AGX125EF35C5G - Active
9. EP2AGX190EF29C6G - Active
10. EP2AGX65DF25C5G - Active
11. EP2AGX65DF29C5G - Active
12. EP2AGX95EF29C5G - Active
13. EP2C15AF256C6N - Active
14. EP2C5T144C8N - Active
15. EP3C10F256C8N - Active
16. EP3C16F484C8N - Active
17. EP3C40F484C6N - Active
18. EP3C40F484C8N - Active
19. EP3C40F780C6N - Active
20. EP3C80F484C8N - Active
21. EP3SL200F1152C2G - Active
22. EP3SL340H1152C2G - Active
23. EP4CE10F17C8N - Active
24. EP4CE6F17C8N - Active
25. EP4CGX22CF19C8N - Active
26. EP4SGX230FF35C2N - Active
27. EP4SGX230FF35C2NES - Active
28. EP4SGX230FF35C2XG - Active
29. EP4SGX360FF35C2XG - Active
30. EPCQ64ASI16N - Active
31. EPM1270F256C5N - Active
32. EPM1270T144C3N - Active
33. EPM2210F256C5N - Active
34. EPM2210F256C7N - Active
35. EPM240T100C5N - Active
36. EPM570F100C5N - Active
37. EPM570F256C5N - Active
38. EPM570GF256C5N - Active
39. EPM570T100C5N - Active
40. EPM570T144C4N - Active
41. EW31244
42. EX1AV
43. FH8065301487717 SR3UT
44. FH8070304243832
45. FH8070304243833
Hope that answers your question and sorry for the inconvenience.
Nazrul Naim
Componentengineer
Hi Team,
Please provide the YEOL date of that Active part MPN's.
Ajithkumar.
Sara_Khaled
Hello Nazrul Naim,
Thanks for your data.
But for the following parts that are Active, I found the series is NRND based on this link https://www.intel.com/content/www/us/en/products/details/fpga/max.html
so we need to know if they are Active or NRND now.
EPM570T100C5NIntel
EPM570F100C5NIntel
EPM570F256C5NIntel
Sara Khaled
NazrulNaim_Intel
It has been a while since your last update. Is there anything else that I can help you with this case.
Nazrul Naim
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
Componentengineer
Hi Team,
Please provide the MPN's Life cycle status. If MPN's went to obsolete, share me the EOL notify documents for that.
MPN's,
EE82802AB
EX1AV
FH8070304243832
FH8070304243833
Ajithkumar.
