Hi Team,
Can you please provide the life cycle status of below following MPN's.
1. | AT80571PH0723ML |
2. | AT80614005073AB |
3. | AU80610006225AA |
4. | CM8066201920404 SR2L6/LGA1151 |
5. | EE82802AB |
6. | EN80C31BH1 |
7. | EP2AGX125DF25C5G |
8. | EP2AGX125EF35C5G |
9. | EP2AGX190EF29C6G |
10. | EP2AGX65DF25C5G |
11. | EP2AGX65DF29C5G |
12. | EP2AGX95EF29C5G |
13. | EP2C15AF256C6N |
14. | EP2C5T144C8N |
15. | EP3C10F256C8N |
16. | EP3C16F484C8N |
17. | EP3C40F484C6N |
18. | EP3C40F484C8N |
19. | EP3C40F780C6N |
20. | EP3C80F484C8N |
21. | EP3SL200F1152C2G |
22. | EP3SL340H1152C2G |
23. | EP4CE10F17C8N |
24. | EP4CE6F17C8N |
25. | EP4CGX22CF19C8N |
26. | EP4SGX230FF35C2N |
27. | EP4SGX230FF35C2NES |
28. | EP4SGX230FF35C2XG |
29. | EP4SGX360FF35C2XG |
30. | EPCQ64ASI16N |
31. | EPM1270F256C5N |
32. | EPM1270T144C3N |
33. | EPM2210F256C5N |
34. | EPM2210F256C7N |
35. | EPM240T100C5N |
36. | EPM570F100C5N |
37. | EPM570F256C5N |
38. | EPM570GF256C5N |
39. | EPM570T100C5N |
40. | EPM570T144C4N |
41. | EW31244 |
42. | EX1AV |
43. | FH8065301487717 SR3UT |
44. | FH8070304243832 |
45. | FH8070304243833 |
Ajithkumar
what do you want to do
Good day
Thank you for reaching out. I'm Nazrul Naim looking into your issue and allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
Sorry for the delay. Below the information needed for the devices. This tech support is focusing on Intel FPGA family. Unfortunately, we can't support any issue that is not related to FPGA.
1. AT80571PH0723ML
2. AT80614005073AB
3. AU80610006225AA
4. CM8066201920404 SR2L6/LGA1151
5. EE82802AB
6. EN80C31BH1
7. EP2AGX125DF25C5G - Active
8. EP2AGX125EF35C5G - Active
9. EP2AGX190EF29C6G - Active
10. EP2AGX65DF25C5G - Active
11. EP2AGX65DF29C5G - Active
12. EP2AGX95EF29C5G - Active
13. EP2C15AF256C6N - Active
14. EP2C5T144C8N - Active
15. EP3C10F256C8N - Active
16. EP3C16F484C8N - Active
17. EP3C40F484C6N - Active
18. EP3C40F484C8N - Active
19. EP3C40F780C6N - Active
20. EP3C80F484C8N - Active
21. EP3SL200F1152C2G - Active
22. EP3SL340H1152C2G - Active
23. EP4CE10F17C8N - Active
24. EP4CE6F17C8N - Active
25. EP4CGX22CF19C8N - Active
26. EP4SGX230FF35C2N - Active
27. EP4SGX230FF35C2NES - Active
28. EP4SGX230FF35C2XG - Active
29. EP4SGX360FF35C2XG - Active
30. EPCQ64ASI16N - Active
31. EPM1270F256C5N - Active
32. EPM1270T144C3N - Active
33. EPM2210F256C5N - Active
34. EPM2210F256C7N - Active
35. EPM240T100C5N - Active
36. EPM570F100C5N - Active
37. EPM570F256C5N - Active
38. EPM570GF256C5N - Active
39. EPM570T100C5N - Active
40. EPM570T144C4N - Active
41. EW31244
42. EX1AV
43. FH8065301487717 SR3UT
44. FH8070304243832
45. FH8070304243833
Hope that answers your question and sorry for the inconvenience.
Nazrul Naim
Hi Team,
Please provide the YEOL date of that Active part MPN's.
Ajithkumar.
It has been a while since your last update. Is there anything else that I can help you with this case.
Nazrul Naim
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
