Following exceptional error observed when ADC core is instantiated in the quartus prime device
Problem Details
Error:
*** Fatal Error: Access Violation at 0X00007FFE18DFE84C
Module: quartus_fit.exe
Stack Trace:
0x3e84b: DEV_PKG_INFO_BODY::get_pin_string_data + 0xeb (DDB_DEV)
0x15f3c3: FIOMGR_STRATIXIII_DYNAMICTERMINATIONCONTROL_LEGALITY::operator= + 0xa3f93 (FITTER_FIOMGR)
0x160e66: FIOMGR_STRATIXIII_DYNAMICTERMINATIONCONTROL_LEGALITY::operator= + 0xa5a36 (FITTER_FIOMGR)
0x138159: FIOMGR_STRATIXIII_DYNAMICTERMINATIONCONTROL_LEGALITY::operator= + 0x7cd29 (FITTER_FIOMGR)
0x8236a: FIOMGR_IO_MANAGER_INTERFACE::operator= + 0x16fca (FITTER_FIOMGR)
0x164c67: FIOMGR_STRATIXIII_DYNAMICTERMINATIONCONTROL_LEGALITY::operator= + 0xa9837 (FITTER_FIOMGR)
0x134667: FIOMGR_STRATIXIII_DYNAMICTERMINATIONCONTROL_LEGALITY::operator= + 0x79237 (FITTER_FIOMGR)
0x135364: FIOMGR_STRATIXIII_DYNAMICTERMINATIONCONTROL_LEGALITY::operator= + 0x79f34 (FITTER_FIOMGR)
0x9d01f: FIOMGR_IO_MANAGER::legality_check + 0x22f (FITTER_FIOMGR)
0xa3bb4: FIOMGR_IO_MANAGER::update_io_manager_atom_information + 0x174 (FITTER_FIOMGR)
0x9f2ce: FIOMGR_IO_MANAGER::post_fit_legality_check + 0x12e (FITTER_FIOMGR)
0xbcb7: fcuda_execute + 0x21d7 (fitter_fcuda)
0x55230: FITCC_EXPERT::fitter_post_check + 0x1b0 (FITTER_FITCC)
0x5697a: FITCC_EXPERT::invoke_fitter + 0x8fa (FITTER_FITCC)
0x9ccb: fcuda_execute + 0x1eb (fitter_fcuda)
0xeb9b: fmain_start + 0x8eb (FITTER_FMAIN)
0x18367: Legacy_fitter_Unload + 0x6b7 (comp_qfit_legacy_flow)
0x14410: TclInvokeStringCommand + 0xf0 (tcl86)
0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
0x17a65: Tcl_EvalEx + 0xa95 (tcl86)
0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5646: Tcl_EvalFile + 0x36 (tcl86)
0x12877: qexe_evaluate_tcl_script + 0x367 (comp_qexe)
0x11ac3: qexe_apply_ini_vars + 0x2763 (comp_qexe)
0x16c34: qexe_run_tcl_option + 0x584 (comp_qexe)
0x39285: qcu_run_tcl_option + 0xf95 (comp_qcu)
0x1658d: qexe_process_cmdline_arguments + 0x260d (comp_qexe)
0x17371: qexe_standard_main + 0xc1 (comp_qexe)
0x13258: msg_initialize_out_of_memory_handler + 0x368 (CCL_MSG)
0x14a5e: msg_set_stack_size + 0x7e (CCL_MSG)
0x16af0: mem_tbb_tracking_flush_peak + 0x2b0 (ccl_mem)
0x12af1: msg_exe_main + 0xa1 (CCL_MSG)
0x17c23: BaseThreadInitThunk + 0x13 (KERNEL32)
0x6d720: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 20.1.0
Build: 711
Edition: Standard Edition
I am enquiring about this error with our internal team. Will keep you posted when I get the information.
Is it possible for you to provide a sample design where this error can be reproduced. .qar would be helpful.
Regards.
This error appeared when we integrated ADC with our design
We need a reference design to reproduce this error. Please provide the same.
Regards.
Looks like bug in 20.1.x versions, I tried 19 version --> works fine.
Please let us know once you release next stable version
Hi Hariprasad,
Glad to know that you can go ahead for now. To understand what caused this issue, and to help fix it in future Quartus releases, please provide an example scenario to reproduce the error. It would be of great help to all of our customers.
Regards.
With all 4 PLLs utilized, instantiate ADC in the MAX 10, then you will see the above error
