21593 Discussions
MAX 10 POR voltage threshold
ErikW
What are the POR voltage thresholds for the MAX10?
VCC
VCCA
VCCIO banks 1B and 8
Ash_R_Intel
At any given point of time, the voltages should not exceed the recommended range. Please refer the datasheet.
Dual Supply Devices Power Supplies Recommended Operating Conditions
ErikW
What are the voltage thresholds at which a Power-on-Reset will be triggered?
Ash_R_Intel
Please refer to the following document page: 2.2. Power-On Reset Circuitry
The POR circuitry ensures that the voltages are within the limit specified in the datasheet. So, if any rail goes below the min limit or max limit POR circuitry is triggered.
Hope that helps.
FvM
don't expect specifications beyond datasheet figures. Minimal specified VCC/VCCA/VCCIO minus a margin for comparator threshold variation is the answer. If you want to know actual POR threshold of your device under test for some reason, perform own measurements.
Ash_R_Intel
As the query has been answered, I am setting the case to closure. However, it will still be available for other community members to comment on.
