Programmable Devices
21090 Discussions
MAX 3000A EPM3256ATC144-10N vs MAX V 5M1270ZT144 (Size comparison)
sth125
Our hardware group is reimplementing an existing design.  They decided to change some CPLDs from a MAX 3000A EPM3256ATC144-10N  to a MAX V 5M1270ZT144.
I am going to add a 16-bit pulse counter plus some other logic to the existing CPLD logic, so I am trying to ascertain how much bigger the MAX V is than the MAX 3000A part.  I only have a images of the existing CPLD logic so I am not sure how much space the existing design uses.
Here is what I know:
MAX 3000A
16 LABs
16 LABs * 16 Macrocells/LABs = 256 Macrocells
Macrocell has 5 input product terms and a clocked register
MAX V
127 LABs
127 LABs * 10 LE/LABs = 1270 LE
LE has a 4 input LUT and a clocked register
The MAX V seems to be significantly larger, especially given each LE has a LUT.
am I correct?  How much larger is it?
Stephen
NazrulNaim_Intel
For your information, The EPM3256ATC144-10N has around 2500 logic elements while 5M1270ZT144 has 12000 logic elements. So 5M1270ZT144 is significantly larger than EPM3256ATC144-10N.
Hope that answers your question.
Nazrul Naim
NazrulNaim_Intel
Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
NazrulNaim_Intel
Nazrul Naim
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, for now I will set this case to Close-Pending.
Nazrul Naim
