21602 Discussions
MAX II vs MAX V??
FCaña
We have an old design using MAX II family, particulary the CPLD EPM2210F256I5N and we want to improve this design usign the MAX V family with the CPLD 5M2210ZF256I5N. I know that it is full compatible pinout but I want to know if there are any other problem or changes includes in this improvement, like software changes or something different.
HBhat2
New Contributor II
I found a similar discussion link
https://forums.intel.com/s/question/0D50P00003yyNpBSAU/max-ii-to-max-v-migration
Also, you need to use the proper Quartus tool version which supports Max V devices
With regards,
HPB
FCaña
Thank you for the information but in that discussion they don´t response the main issue.
Can you give me additional information?
Thanks you in advance
JohnT_Intel
There will no be any problem as the design will be re-synthesis for Max V design as the architecture for this device is different compare to Max II device. The performance will also be better.
FCaña
So, if i change the CPLD, the software will automatically re-synthesis or I will do it again for the MAX V?
Thanks in advance
JohnT_Intel
You will need to change the device used for your Quartus design before re-compiling the design.
