21259 Discussions
MAX V Device ID failures
AL-D
we brokered some devices with the current material situation.
We purchased 400 pieces of 5M570ZT100C4N with date codes 1325 and 1337.
we had the parts tested prior to sending to our CM.  the test house provided the following data:
all passed with the correct device ID
the parts are at our CM and they have a 66% failure at programing, failing the device ID check.
we are not sure why we have this issue since the parts were tested prior to programming.
YuanLi_S_Intel
It looks like you are using custom programmer to do programming. With 6/400 unit having issue only, it sounds to me that some of the part might have problem.
But anyway, what programming file you are programming? Also, is it possible to test with quartus programmer to do programming?
AL-D
thank you for the suggestions.  I will ask my CM if they have the quartus sw.
For programming they are currently using:
Manufacturer
Model
S/W
S/W Rev
Adapter
ELNEC
BeeHive204
Pg4uw
V3.38D
DIL48/QFP100 ZIF PLD-17
Data IO
PSV5000
TaskLink
V9.01
Q2861
they are using an .eprj project file Elnec for programming.
YuanLi_S_Intel
Seems like .eprj is your own programming file. Could it be the file converting issue? Apologize that we are not able to support as we are only able to debug our own programming file issue such as SOF, POF, JIC and etc.
MBenca
Hi AL-D,
I would recommend to ask the same question in Elnec company via: www.elnec.com/en/support/problem-report/
Martin
