Programmable Devices
20684 Discussions
MAX10 管脚的速率
RXie
Partner
MAX10的管脚 IO Performance 分了 high_speed和low_speed两种,这个的高低速率分别为多少了?
ShafiqY_Intel
Hi RXie,
For MAX 10 IO banks location (high speed IO or low speed), you may refer below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_gpio.pdf
For high &low rate, you may refer to MAX 10 Datasheet:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
RXie
Partner
我意思是这个high_speed和low_speed的具体数值是多少了?
ShafiqY_Intel
RXie,
The rate value of high_speed & low_speed varies. It's depend on timing specification
For example, Dual Supply Devices True RSDS and Emulated RSDS_E_3R Transmitter Timing Specifications data rate as below:
