Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
MAX10 - 10M02DCV36I7G - BOARD - High current draw or shortcircuit ?
Hi all,
Target : MAX10 - 10M02DCV36I7G
Quartus: 15.1
We are trying to design a very minimalist and small MAX10 FPGA board using the 10M02DCV36I7G. The schematic (attached) of the board is very simple and only implement the following features :
  • Single 3.3V supply power : VCCIO3_5_6 = VCCIO_1_2_8 = VCCA = VCC_ONE and are all connected to a single 3.3V LDO regulator
  • We aim to implement a SPI compatible bus. Considering the small amount of IO on this chip we decided to use the JTAG Pins Sharing features
  • The FPGA is clocked with a 50MHz Resonator
  • And a small led is connected to one of the digital I/O
  • Other IO are connected to board pins or left unconnected
the problem :
When we power the board the board draw a large amount of current (>400mA) and the voltage drops. So there must be a short-circuit somewhere but we are unable to locate it. We tried several approaches:
We probably missed something and are now out of ideas...
Thanks for your help.
Tim
Tags (1)
Is the device orientation correct? What solder paste stencil and aperture did the CEM use for the BGA? My money is on a short, regardless what the CEM stated about AOI - that can't see under the device. Can they X-ray the device for you?
Cheers,
Alex
10M02DCV36I7G is a dual supply device.
