Programmable Devices
Объявления
21615 Обсуждение
MAX10 ADC problem
EEren
Новичок
1 402Просмотр.
I created an ADC module in Qsys
component adc_qsys is port ( adc_1_command_valid : in std_logic := '0'; -- adc_1_command.valid adc_1_command_channel : in std_logic_vector(4 downto 0) := (others => '0'); -- .channel adc_1_command_startofpacket : in std_logic := '0'; -- .startofpacket adc_1_command_endofpacket : in std_logic := '0'; -- .endofpacket adc_1_command_ready : out std_logic; -- .ready adc_1_response_valid : out std_logic; -- adc_1_response.valid adc_1_response_channel : out std_logic_vector(4 downto 0); -- .channel adc_1_response_data : out std_logic_vector(11 downto 0); -- .data adc_1_response_startofpacket : out std_logic; -- .startofpacket adc_1_response_endofpacket : out std_logic; -- .endofpacket adc_2_command_valid : in std_logic := '0'; -- adc_2_command.valid adc_2_command_channel : in std_logic_vector(4 downto 0) := (others => '0'); -- .channel adc_2_command_startofpacket : in std_logic := '0'; -- .startofpacket adc_2_command_endofpacket : in std_logic := '0'; -- .endofpacket adc_2_command_ready : out std_logic; -- .ready adc_2_response_valid : out std_logic; -- adc_2_response.valid adc_2_response_channel : out std_logic_vector(4 downto 0); -- .channel adc_2_response_data : out std_logic_vector(11 downto 0); -- .data adc_2_response_startofpacket : out std_logic; -- .startofpacket adc_2_response_endofpacket : out std_logic; -- .endofpacket clk_clk : in std_logic := '0'; -- clk.clk reset_reset_n : in std_logic := '0' -- reset.reset_n ); end component adc_qsys;
and connected to signals
signal adc1_com_valid : std_logic; signal adc1_com_channel : std_logic_vector(4 downto 0); signal adc1_com_startofpacket : std_logic; signal adc1_com_endofpacket : std_logic; signal adc1_com_ready : std_logic; signal adc1_reset_n : std_logic; signal adc1_resp_valid : std_logic; signal adc1_resp_channel : std_logic_vector(4 downto 0); signal adc1_resp_data : std_logic_vector(11 downto 0); signal adc1_resp_startofpacket : std_logic; signal adc1_resp_endofpacket : std_logic; signal adc1_sample_time : std_logic_vector(31 downto 0) := (others => '0');   signal adc1_1_data : std_logic_vector(11 downto 0); signal adc1_2_data : std_logic_vector(11 downto 0); signal adc1_3_data : std_logic_vector(11 downto 0); signal adc1_4_data : std_logic_vector(11 downto 0); signal adc1_5_data : std_logic_vector(11 downto 0); signal adc1_6_data : std_logic_vector(11 downto 0); signal adc1_7_data : std_logic_vector(11 downto 0); signal adc1_8_data : std_logic_vector(11 downto 0);   signal adc2_com_valid : std_logic; signal adc2_com_channel : std_logic_vector(4 downto 0); signal adc2_com_startofpacket : std_logic; signal adc2_com_endofpacket : std_logic; signal adc2_com_ready : std_logic; signal adc2_reset_n : std_logic; signal adc2_resp_valid : std_logic; signal adc2_resp_channel : std_logic_vector(4 downto 0); signal adc2_resp_data : std_logic_vector(11 downto 0); signal adc2_resp_startofpacket : std_logic; signal adc2_resp_endofpacket : std_logic; signal adc2_sample_time : std_logic_vector(31 downto 0) := (others => '0');   signal adc2_1_data : std_logic_vector(11 downto 0); signal adc2_2_data : std_logic_vector(11 downto 0); signal adc2_3_data : std_logic_vector(11 downto 0); signal adc2_4_data : std_logic_vector(11 downto 0); signal adc2_5_data : std_logic_vector(11 downto 0); signal adc2_6_data : std_logic_vector(11 downto 0); signal adc2_7_data : std_logic_vector(11 downto 0); signal adc2_8_data : std_logic_vector(11 downto 0);     U_ADC : adc_qsys port map ( clk_clk => G_CLK, reset_reset_n => '1', adc_1_command_valid => adc1_com_valid, adc_1_command_channel => adc1_com_channel, adc_1_command_startofpacket => adc1_com_startofpacket, adc_1_command_endofpacket => adc1_com_endofpacket, adc_1_command_ready => adc1_com_ready, adc_1_response_valid => adc1_resp_valid, adc_1_response_channel => adc1_resp_channel, adc_1_response_data => adc1_resp_data, adc_1_response_startofpacket => adc1_resp_startofpacket, adc_1_response_endofpacket => adc1_resp_endofpacket, adc_2_command_valid => adc2_com_valid, adc_2_command_channel => adc2_com_channel, adc_2_command_startofpacket => adc2_com_startofpacket, adc_2_command_endofpacket => adc2_com_endofpacket, adc_2_command_ready => adc2_com_ready, adc_2_response_valid => adc2_resp_valid, adc_2_response_channel => adc2_resp_channel, adc_2_response_data => adc2_resp_data, adc_2_response_startofpacket => adc2_resp_startofpacket, adc_2_response_endofpacket => adc2_resp_endofpacket );
Now I want to scan the channels
signal chan : std_logic_vector(4 downto 0) := "00000";   ADC1_SCAN : process(G_CLK) begin   if rising_edge(G_CLK) then case Adc1State is when ST_WAIT_FOR_SAMPLE => adc1_sample_time <= adc1_sample_time + '1'; if (adc1_sample_time = X"0000000000989680") then --100 ms adc1_sample_time <= (others => '0'); Adc1State <= ST_SELECT_CHAN; end if; when ST_SELECT_CHAN => if (chan = "01000") then chan := "00001"; else chan := chan + '1'; end if; Adc1State <= ST_START_CONV;   when ST_START_CONV => adc1_com_channel <= chan; adc1_com_valid <= '1'; Adc1State <= ST_WAIT_FOR_DONE; when ST_WAIT_FOR_DONE => adc1_com_valid <= '0'; if (adc1_resp_valid = '1') then Adc1State <= ST_DATA_READY; end if; when ST_DATA_READY => case chan is when "00001" => adc1_1_data <= adc1_resp_data; when "00010" => adc1_2_data <= adc1_resp_data; when "00011" => adc1_3_data <= adc1_resp_data; when "00100" => adc1_4_data <= adc1_resp_data; when "00101" => adc1_5_data <= adc1_resp_data; when "00110" => adc1_6_data <= adc1_resp_data; when "00111" => adc1_7_data <= adc1_resp_data; when "01000" => adc1_8_data <= adc1_resp_data; when others => Adc1State <= ST_WAIT_FOR_SAMPLE; end case; Adc1State <= ST_WAIT_FOR_SAMPLE; when others => Adc1State <= ST_WAIT_FOR_SAMPLE; end case; end if;   end process ADC1_SCAN;
And I have a module to read results (with SPI bus)
U_REG_FILE : REG_FILE generic map ( SPI_DATA_WIDTH => 8 ) port map ( REG_CLK => G_CLK, REG_RST => '0',   ADC1_1_DATA => adc1_1_data, ADC1_2_DATA => adc1_2_data, ADC1_3_DATA => adc1_3_data, ADC1_4_DATA => adc1_4_data, ADC1_5_DATA => adc1_5_data, ADC1_6_DATA => adc1_6_data, ADC1_7_DATA => adc1_7_data, ADC1_8_DATA => adc1_8_data, ADC2_1_DATA => adc2_1_data, ADC2_2_DATA => adc2_2_data, ADC2_3_DATA => adc2_3_data, ADC2_4_DATA => adc2_4_data, ADC2_5_DATA => adc2_5_data, ADC2_6_DATA => adc2_6_data, ADC2_7_DATA => adc2_7_data, ADC2_8_DATA => adc2_8_data );
If I close the U_REG_FILE - it compiles OK. If it's enabled I get
Error (170084): Can't route signal "adc_qsys:U_ADC|adc_qsys_ADC1_PLL:adc1_pll|adc_qsys_ADC1_PLL_altpll_gr22:sd1|wire_pll7_clk[0]" to atom "adc_qsys:U_ADC|adc_qsys_ADC_1:adc_1|altera_modular_adc_control:control_internal|fiftyfivenm_adcblock_top_wrapper:adc_inst|fiftyfivenm_adcblock_primitive_wrapper:adcblock_instance|primitive_instance"
What is the problem?
0 баллов
3 Ответы
sstrell
Почетный участник III
1 150Просмотр.
According to the user guide (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_adc.pdf) the c0 clock of the PLL is supposed to be dedicated to the ADC, but that doesn't explain why your state machine, clocked by the same clock (G_CLK), is compiling OK without the register file. Does the state machine work without the register file enabled?
#iwork4intel
EEren
Новичок
1 150Просмотр.
Thank you very much. Indeed it have to be routed to PLL signal. Now it runs. I see all the signals on Signal Tap but the flag adc1_resp_valid never goes high and adc1_resp_data always zero. May be I do something wrong in the state machine?
EEren
Новичок
1 150Просмотр.
I found the problem - the pll clock has to be exactly as defined in the core. Now I have valid results on all channels.
Ответить
