21256 Discussions
MAX10 Dual boot - is dual NIOS SW possible?
jackhab
I'm starting with MAX10 RSU project and there is a image layout issue that is not clear to me.
I need to have two FPGA designs: a factory design (capable of RSU) and a final application design. Each design also has its own NIOS SW.
The on-chip flash IP has Initialize Flash Content Option set to OFF so that I will be able to add mem_init SW image later.
In Convert Programming Files I create a POF from the two SOFs on page_0 and page_1.
Now I want to attach each NIOS SW hex image to its corresponding FPGA design but Boot Info dialog only allows one hex file on UFM.
Is it even possible to pack two different SW images for CFM0 and CFM1 SOFs or I can only have one SW image on UFM and it must be shared by both FPGA designs?
KellyJialin_Goh
Greetings and welcome to Intel's Forum.
Unfortunately, the UFM data (.HEX file) can be included in either Page_0 or Page_1 only. The On-chip flash does not support two .HEX files for Dual Compressed images configuration mode.
Here are additional information on the Max10 On Chip Flash for your reference:https://www.intel.com/content/www/us/en/docs/programmable/683689/current/fpga-on-chip-flash-description.html
Hope this clarify your doubts.
Thank you.
Kelly Jialin, GOH
KellyJialin_Goh
Thank you.
Kelly Jialin, GOH
KellyJialin_Goh
Any updates from you end whether the feedback provided is useful?
Thank you.
Kelly
jackhab
KellyJialin_Goh
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Thank you.
Kelly Jialin, GOH
