Programmable Devices
20704 Discussions
MAX10 : Error (169049): Enable Bus-Hold Circuitry and Weak Pull-Up Resistor logic
Error (169049): Enable Bus-Hold Circuitry and Weak Pull-Up Resistor logic options cannot both be enabled for ~ALTERA_TMS~ pin
Error (169049): Enable Bus-Hold Circuitry and Weak Pull-Up Resistor logic options cannot both be enabled for ~ALTERA_TDI~ pin
Using Altera MAX10 Dev Kit
10M08SAE144C8G
Quartus Prime Lite 16.0.0
Edit Settings
Compiler Settings
Advanced Fitter Settings
Enable Bus-Hold Circuitry = ON
MAX10 TMS and TDI have on IC weak pull ups - so the SW thinks there is a problem with TMS and TDI.
Weak pull-ups ARE NOT turned on.
Any ideas on this?
My goal is to get bus-hold enabled on the MAX10 pins during user mode.
