MAX10: JTAG ISP
Jo910
I plan to use a MAX 10M02SCE144I7G FPGA on my next PCB. FPGA code will be generated by Quartus. I know how to programm FPGA by using external JTAG header, but I want to programm FPGA with a Microprocessor via ISP. Is there another possibility to programm FPGA without using JTAG? What solution whould be the easiest way to implement a ISP for MAX 10 connected with a Microprocessor?
NurAiman_M_Intel
Thank you for contacting Intel community.
Have you refer to Max10 configuration userguide for implementing ISP? It is recommended to follow Intel configuration userguide below for further information. Let us know your concern.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Aiman
