21615 Discussions
MAX10 JTAG inaccessible after programming
sparky
I'm working with a MAX10M04 and am having some programming issues.  The programmer always reports "(failed)" in the progress bar when programming is complete and no further JTAG access is possible without power cycling.  Error 209040, "can't access JTAG chain", is reported in the log.  Despite this, the device appears to be configured correctly, suggesting the JTAG becomes non-functional once the design goes live.  Initially I'm just using CRAM and have not attempted to program the flash.
Quartus configuration settings are:
  • nCONFIG, nSTATUS and CONF_DONE disabled (these are pulled high on the target board)
  • JTAG pin sharing disabled
  • Unused pins: as input tri-stated
The JTAG pins are dedicated and not connected to any user logic on the PCB.
I'm fairly new to using the MAX10, so I expect there's something I've missed.  Does anyone have any suggestions please?
Sparky
sparky
No need for feedback on this one now.  Problem solved.
It was something obvious.  There was a solder bridge between TDO and the adjacent i/o pin on the MAX10.
YuanLi_S_Intel
I am glad it works now. Let us know if got any further problem.
