21602 Discussions
MAX10 Timing Constraints for a Clock Enable fanout?
TWell6
I'm working on a project for a MAX10 FPGA, using a clock enable, ClkEnBuffer, which reduces the clock speed by 4.
I've had a look at a Timing Analyzer example (https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-examples/design-software/timinganalyzer/exm-tq-clock-enable.html) and modify that.
set_multicycle_path -to [get_fanouts [get_pins {*|CDR|ClkEnBuffer|q*} ] -through [get_pins -hierarchical *|*ena*]] -end -setup 4
set_multicycle_path -to [get_fanouts [get_pins {*|CDR|ClkEnBuffer|q*} ] -through [get_pins -hierarchical *|*ena*]] -end -hold 1
With the multicycle constraints commented out, Quartus completes with no negative slack. With the constraints active, Quartus completes with lots of timing errors (All of them with excess routing delays) up to 2 * ClkEnBuffer delay (8 * clock).
Could anyone help please?
Quartus: Quartus Prime Lite 19.1.0 Edition
sstrell
Your hold multicycle value should be one less than your setup multicycle, so it should be 3 instead of 1. The example you link to has enable every other cycle which is why 2 and 1 are used there. You need to use 4 and 3 for your enable every 4 cycles. Try that and report back.
#iwork4intel
KhaiChein_Y_Intel
Can you share the design for investigation? What is the edition (Pro/Standard) and version you are using?
KhaiY
TWell6
As I put on the original question:
sstrell
#iwork4intel
TWell6
Thanks sstrell - It's multicycling.
