21611 Discussions
MAX10 UFM Read Operation
SMS
I am trying to read from MAX10's UFM but the device does not assert the readdatavalid signal as specified in UFM user guide. Any guess why is it so? I am sharing the relevant code below:
task data_read_top; case (read_state) FLASH_READ_IDLE : begin read_state <= FLASH_READ1; end FLASH_PRE_READ : begin if (avmm_data_waitrequest) read_state <= FLASH_PRE_READ; else read_state <= FLASH_READ1; end FLASH_READ1 : begin data_read1(00000_0101_1111_0000); read_state <= FLASH_READ2; end FLASH_READ2 : begin data_read2; read_state <= FLASH_READ3; end FLASH_READ3 : begin if (~avmm_data_readdatavalid) begin read_state <= FLASH_READ3; end else begin data_read3; data_out <= avmm_data_readdata; read_state <= FLASH_READ4; end end FLASH_READ4 : begin read_state <= FLASH_READ_IDLE; end default : read_state <= FLASH_READ_IDLE; endcase     endtask   task data_read1; input [16:0] addr; begin avmm_csr_read <= 1'b0; avmm_csr_write <= 1'b0; avmm_csr_addr <= 1'b0; avmm_data_addr <= addr; avmm_data_read <= 1'b1; avmm_data_burstcount <= 2'b01; end endtask task data_read2; begin avmm_csr_read <= 1'b0; avmm_csr_write <= 1'b0; avmm_csr_addr <= 1'b0; avmm_data_read <= 1'b0; avmm_data_addr <= 17'b0000_0000_0000_0000_0; avmm_data_burstcount <= 2'b00; end endtask   task data_read3; begin avmm_csr_read <= 1'b0; avmm_csr_write <= 1'b0; avmm_csr_addr <= 1'b0; end endtask
The task data_read_top itself is called in another case statement. What I have observed in SignalTap II is that it remains stuck at state FLASH_READ3.
SAR
Not able to understand the state machine can you post full code?
Have you checked your logic using modelsim?
I can simulate the Flash IP, it works fine. Attached the image.
So for debugging check your logic using modelsim first.
SMS
Thanks for the reply. My code is attached. Actually I tried simulating the design first but Modelsim gives these errors:
  1. Instantiation of 'altera_onchip_flash_avmm_data_controller' failed. The design unit was not found.
  2. Instantiation of 'fiftyfivenm_unvm' failed. The design unit was not found.
which I am unable to resolve, so moved directly to post synthesis verification.
Another thing that I have observed is if I remove the wait condition for 'readdatavalid' signal, it gets asserted by the UFM core and data is shared on the data bus but is mismatched from the address.
Besides can you explain, that you sent a read request for data to be read from 17'h00000 and 17'h00001 but it seems that UFM read some different data.
Sarmad
Shweta_sawant
Please Reply,
We are facing the same error. Its on priority.
Best regards
Shweta Sawant
