Programmable Devices
21018 Discussions
MAX10 weak pull-ups and leakage current
foft
I'm seeing significant impact from enabling weak pull-ups on pins other than the one I am using.
The specific case is as follows:
Device 10M02SCU169C8G.
In this design I have C1 and D1 connected together. I saw them pulling up with approximately 160uA when tri-stated. I.e. I see 0.8v on the pin if I use a 5K resistor to pull to ground.
I noticed that if I disable the weak-pull up on C2 then the leakage current on C1/D1 vanishes. Note that in my design C2 is actually an unused pin, the weak pull-up was on by default by the 'as input tri-stated with weak pull-up' option for unused pins.
Is this a known issue, perhaps related to the other half of a differential pair?
AminT_Intel
This may happen because of leakage current in Max 10 device. There is a detail about tristated I/O pin on page 9 from this link: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
foft
I saw that, but its talking about +/-10uA. 160uA is a fair bit higher. It does say that the 10uA may be exceeded when using the clamp diodes. In fact that isn't what I see here. I see it happen not with the clamp diodes but the weak pull up on another pin that I'm not using.
AminT_Intel
May I know which version of Quartus are you using and if you can share you sample design.
foft
I've seen this in Quartus lite versions for the last few years, now using v20.1. I'll post the .qar this evening.
AminT_Intel
Is there any update from your end? I will close this case in 3 days from today if there is no update from you.
Thank you.
AminT_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
foft
Sorry I was a bit caught up with some things, I'd post it now but guess its too late.
