Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
MAX7000 (EPM7032) power cut during programming -> can not program any more
I had to perform emergency power cut during JTAG programming cycle because other chip started to heat (the cause is wrong output level of unprogrammed CPLD). Now I can not reprogram device any more - programmer gives error almost immediately. JTAG BST is on, security bit it off in PFO file. Will appreciate any advice how to revive the chip. Thank you.
Highlighted
I can't help but I am curious as to what you're using to program the chip.. Hardware/Software?
